Grinding/scraping/noise
How's it going everyone? Quick background about myself...I got my first CJ (an '86) in 2000. I drove that daily for about 9 years. I replaced it with a TJ, since it was rusting out from under me. I then got rid of the TJ and picked up an '84 CJ with a T-5 about 3 years ago. Alright, now for the problem. When I start the Jeep, everything is quiet. I push the clutch in and there's no noise and it goes into each gear easily still with no noise. Also, the Transfer Case shifts through the gears as easily as it always has. As soon as I let the clutch out it slightly clunks and then there's a scrape scrape scrape scrape scrape noise. It does it in reverse or any of the forward gears. If I'm moving and I push the clutch in or put it in neutral, the noise stops. When I put it in 4-wheel Hi, the noise got even worse. I took both driveshafts off, fired it up and ran through the first couple gears and it was dead silent. Then I put the rear shaft back in (still no front shaft), jacked up the rear tires and there was the noise. A month or so before this started, I replaced the Transfer Case and t5s fluid with syncromesh. Both were still full of fluid, so I eliminated that out of the equation but I did drain the Transfer Case and refill it with gl4. I started thinking it was the Dana 300s output shaft bearings, so i started the hunt for one. The rear has no play whatsoever and the front has just enough play that you can feel it but you can't see it, which I'm told by a guy who I went to buy a Dana 300 from is okay. He suggested I try u-joints, which I replaced to no avail. Someone said it could be the rear axle, but it runs perfectly silet and the noise is clearly coming from the Transfer Case /Transmission area. Then I started thinking maybe it's the pilot, throw out or input shaft bearing on the Transmission . Now I think I'm starting to lose my mind because it's all I'm thinking about. I figured I'd better ask you guys before I go crazy. So, after all that, anyone have any ideas?
