Grounding Electrics Clarification
PaRenegade
Crazy Sr. Respected Jeeper
- Media
- 20
- Solutions
- 1
- Lewistown, Pa.
- 1982 Jeep CJ-7 Renegade
258, T-4, D300, trussed AMC20 w/Detroit & 1pc., Dana30 w/TrueTrac, 3.73:1; just finished a restomod
PaRenegade, I like the detail in your system. What did you use to seal up the liqutight? Assuming its dogged off and siliconed,
At the end going into the box (Cantex 4x4) I used a LiquidTight connector and the other end, which isn't hooked up yet (still in mid build stage), I plan on using duct seal putty like is commonly used at the service entrance cable penetration. I'll terminate it under the battery and then put a drip loop right after it.
No toes stepped on here. Just passing on knowledge or methods I've learned of on my Jeep rebuilding journey. I'm no expert, especially when it comes to electrical or electronics. Curious though, if aluminum doesn't handle heat well, and distance builds resistance and therefore heat, why do they use aluminum for the larger service entrance cable and similar large gauge cables like the ones on poles?
