I believe '76 - '86 are the same. There are used ones all around, and even new with tinted glass and struts available for about $2,200 (Rally Tops). Now if only someone would make a "MyTop" powered convertible top for the CJ7 like they have for newer Jeeps. My Top
84 CJ7 4 banger-owned since new in 1984 bought off truck at dealership - rebuilding 258, T176 with Sniper EFI D300 4:1 Lomax gears Twin Sticked 1 piece axels with locker
My newly acquired 1981 CJ7 hardtop is an inch or so wider than my 1980 CJ7 tub! Should it be? Will only 1976-1980 fit? Is this some kind of fiberglass droop? I thought only the track widened in 1981, not the tub and top.
Pictures would definitely be helpful. How are the gaps around the rear lift gate frame? My top flexed a lot one summer when i stored it on an unlevel woodpile, to the point i had to have someone push/hold it while I got the bolts into the tub. It came back into shape after being on the jeep.
Alright I figured it out, with your unintended prodding. The latches on the back door had rusted so bad that they were pushing the bottom of the Top out. Removed the latches (lost a couple of Tork bits), removed the struts (they were locked solid). Removed ALL the soft top retaining pieces (new to me I wasn't sure what stayed, what went). And wrestled with the heavy a%% top for about an hour until it seated properly. Here's a finished picture.
