To celebrate the 4th of July, starting today (07/01/2025) all User Upgrades will be reduced by 10% (thru 07/08/2025) To use this special coupon use the code 2025-4th-10percent at check out. If you are already a supporter your existing package will be extended. Thank you for your support!
I believe '76 - '86 are the same. There are used ones all around, and even new with tinted glass and struts available for about $2,200 (Rally Tops). Now if only someone would make a "MyTop" powered convertible top for the CJ7 like they have for newer Jeeps. My Top
84 CJ7 4 banger-owned since new in 1984 bought off truck at dealership - rebuilding 258, T176 with Sniper EFI D300 4:1 Lomax gears Twin Sticked 1 piece axels with locker
My newly acquired 1981 CJ7 hardtop is an inch or so wider than my 1980 CJ7 tub! Should it be? Will only 1976-1980 fit? Is this some kind of fiberglass droop? I thought only the track widened in 1981, not the tub and top.
Pictures would definitely be helpful. How are the gaps around the rear lift gate frame? My top flexed a lot one summer when i stored it on an unlevel woodpile, to the point i had to have someone push/hold it while I got the bolts into the tub. It came back into shape after being on the jeep.
Alright I figured it out, with your unintended prodding. The latches on the back door had rusted so bad that they were pushing the bottom of the Top out. Removed the latches (lost a couple of Tork bits), removed the struts (they were locked solid). Removed ALL the soft top retaining pieces (new to me I wasn't sure what stayed, what went). And wrestled with the heavy a%% top for about an hour until it seated properly. Here's a finished picture.
1984 cj7 RENEGADE, Hard Top, factory air, reman 304 v8, ax15, D 300, D 30, AMC 20 with one piece axle, welded tubes and a searchers truss system, 4.56 gears, 4" lift, BFG 33x12.5x15, DirtWorx front and rear bumpers, rock sliders
New struts are in. I used D4514. Thanks Senior Jeepers'!
For those Fab Challenged like me, I popped off the metal clips on the backside of the eyelets, Drilled the hole 1/2 inch and all the way through, removed the rubber washers with their metal sleeves from the liftgate bolts Bolts slid right into the new holes. Work great! I was tempted to reuse the metal sleeves but seems to work smoothly without.
