    Thank you for your support!
Wiring Hazzard Light
joeortego
texas
82 jeep cj5
Does anyone have a wiring diagram for the hazards light on a 82 CJ5 , There is nothing on the steering Colum or dash. Where else would it be?
The hazards are controlled by a switch in the turn signal switch inside the column. The hazard switch is activated by pushing/pulling on the switch knob on the lower right of the column near the ignition key. In many cases, this knob may have been knocked off and is longer there. Perhaps why you're unable to locate it. There is a threaded hole in the plastic turn signal assembly that this knob screws into. If the knob and its threaded shaft are both missing, there will be nothing protruding from the blinker switch out of the hole of the column shroud, thus nothing to see unless you look up into there.
View attachment 104283 View attachment 104284
Thanks for the info.
