HD bellcrank build
HD bellcrank build
jeepman038
nj
need direction/site to build bellcrank w/o clipsand plastic bushings pissing me off getting towed home Ican weld just need prts list thx in advance
:wtf: Clutch belcrank? What vehicle? more info-fill profile info.
I have purchased CCVI bearings will fabricate and supply pics was told I might have bad motor mount --noevidence back to fabrication
You may consider converting to a hydraulic clutch.
There was a good thread on that subject here a while ago.
Parts Mike has everything for the conversion.
http://www.partsmike.com/store/store.php?
I got tired of fighting the stock clutch linkage, parts coming apart, especially on the trail. I switched to a hydraulic setup. Was reluctant at first, but that was the best thing I did. I also tried that setup with the chain from Advance Adapters, but it would not fit with dual exhaust. My $.02.
How do you know your motor mounts are good? stockers are rubber and can and do seperate with engine torque thus taking the bellcrank pivot points out of alignment. Poly mounts will provide a more secure system at the expense of increased noise and vibration however minimal.
When I replaced my mounts the pass side was completely seperated and gravity was the only thing working for me.
How are your motor mounts? you should fill out your profile and tell us what engine and drive train you have. The only problem I have ever had with those bushings were because of a broken motor mount letting the motor shift. If you have a V8 it may even be a question of torque. :cool:
If I had taken the time to read the previous post it would have saved me some effort but as you can tell I agree with Sasquach
