hd steering brackett
kenpoman2003
Whitefield, Me
1986 cj7 4" suspension lift, 2" body left. am going to install rear bumper tire carrier, front bumper brush and grill guard, front roll cage and tie in kits. all as money becomes available. dana 30 front end with quadraqtrac four wheel differential. amc 20 locking differentail in the rear. Have solid piece axels just waiting to be installed some slow winters day hopefully in heated garage. Am also going to do, do it yourself paint in tub liner havent decided which one to go with. Any sugestions? hope to do this to the underbody and frame as money allows. I have ordered marine interrior lights for under dash and bach passenger compartment and under hood w/ heavy duty toggle switches. I plan to install a secondary fuse block to acommidate any accessories I may someday get. I know it sounds like a lot but its a pick away project with no deadline. and as money provides.
I have an 86 CJ7 w/power steering. I have purchased a heavy duty steering box brackett. Just want to know how much tear dawn is absolutly needed to in stall this. And info will be greatly appreciated
Thanks:chug:
It depends on the bracket. Which one did you get?
This kind is the easiest to install.
It braces the steering gearbox to the right frame rail.
This kind strengthens the frame around the steering gearbox.
You need to remove the gearbox to install it.
I built one similar to this....I'll have to take some pictures and post em.
the rugged ridge with the back plate
that would br great thanks
I really think the brace is your first upgrade if not doing both, if you upgrade the mount only it is still bolted to a much thinner frame material that will flex. The brace helps in both conditions.
yes I agree, I have the brace also just curious if I'm going to have to remove the power steering line and end up having to bleed the system. Never have done this before could use some advice :)
Yes you will have to take the lines off. Not necessarily at the gear box, better to do it at the pump. Getting the lines on after installing a gearbox can be a little difficult.
Definitely do a test fit of the bracket to the frame before bolting the gearbox to the bracket. (fully bolted to the frame)
PS is more of a "burp" than a bleed. And since you will have the front wheels off the ground to change the bracket, it isn't much more to do to burp the system.
The brace is pretty simple. I had to bend mine (give it a little more angle). Probably got flattened between the factory and me.:D
thanks hopefully i'll have it done this weekend
