HD steering
HD steering
reptile610
st. clair shores, MI
1982 CJ7: 151cu iron duke/ sr-4 trans/ dana 300/ dana 30 front amc 20 rear 3.73 gears.
does anybody make a HD steering upgrade for CJ7 's? i seen the rusty's has a HD tie rod and HD drag link for 100.00 each. anybody else have one?
I run HD ones.
It's true that they won't bend as easly BUT if you hit something with them it puts all the hit onto the rod end and the steering box, instead of bending and taking the shock out of the hit.
very true. so if it came down to replacing stock steering would you do it with HD (running 35's) or just go with oem?
I run HD ones but I flipped my ends to the top of the knuckle to get them up higher. (hopefully out of harms way.)
don't forget to run a steering box brace.
ok it'll be awhile before the jeep is complete but thanks for the info
