heater core
heater core
blue77cj
midwest
77 cj 304 4 speed 4 inch suspention 2 inch body
i have a 77 CJ7 .need to replace the heater core.do i have to remove the dash to get it out?
No 4 1/4" nuts on the firewall side. Disconnect the cab
cables and hoses. Fiberglass housing splits and put the core in. Cores are not that expensive.
actually it is incredibly easy, if you have ever removed a heater core from any other automobile ever built. there is no way to compare the two.:cool:
I changed out my heater core a couple years ago. I have the rollbar front legs running down beside the dash. It makes it a little tougher to do, but still doable. I also replaced some of the seals in side housing with weather stripping.
This is all true if he has the heater unit that sticks through the firewall... in 76 they didn't have this, and I am not sure about 77.
If it sticks through the firewall, you can do all the stuff mentioned, if it does not, you need to get a new motor. I just did this a year ago and let me tell you, it wasn't easy finding one.
Craig
Old style
certifiablejeep.com - Heater Core Replacement - Orange 1976 Jeep CJ5
New style (about half way down the page)
certifiablejeep.com - Project "Curtis Jeep" - part #5
