Heater/Vent rod Connection (pics)
alpha6
Old Time Jeeper
Please look at this diagram. http://www.jeep-cj.com/forums/attachments/f7/12615d1356891204-heater-cabling-heater-cabling.jpg In the top left hand you will see where right above the driver fresh air vent is a lever with a rod that goes along the top of the vents and attaches to a lever noted as the "off-heat-vent." In trying to fix my heat, I found that this bar is not attached at the lever that is in the top left of the diagram. In pic one you can see the rod and end piece and in the background where I believe it is supposed to attach as shown in the diagram. I just can't figure out how this attaches or if I am missing a piece. Also, I found the spring that hooks onto the rod and attached piece (you can see the small hole on the end) but nowhere to hook the other end of the spring in the piece in the background..so maybe I am missing a piece or there is a way these go together.
Any help in getting this together would be great...maybe if someone can get a pic of theirs attached...if I can see it, I am sure I can figure this out. thanks in advance.
