Help! Fuel guage
Help! Fuel guage
This is something that some automatic fans don’t agree on. Automatics should shift rapidly especially under light throttle. The lockup should kick in between 3rd and 4th gears, after Transmission is warm, and disengage if throttle is brought to higher demand AND before 4th to 3rd kickdown. For your specific Transmission , 4th gear should kick in as early as 35 MPH with your 4.88 gears. “or to lock it up in other gears (not sure why you would want that)”: For optimal fuel economy and drivetrain longevity. This is basicaly a stock configuration. As it is, automatics suffer from higher parasitic power losses. You can go into “performance” mode simply by shifting gears manually with your floor nounted shifter.
I thought you went with GPS speedo. Is there a reason you avoided it? Right now I can still decide to go GPS or programmable speedo.
I did install a higher RPM stall torque converter and a shift kit in the tranny. Then also based on TV (throttle valve) cable adjustment, I have the shifting set to points I felt were good or comfortable for my driving style and "butt in the seat" feel. There could be some tweaking for people who want a bit different feel or response. But you're right, under lighter throttle it does shift earlier (about 45 MPH). Under a heavier throttle, it shifts later. And if it's in OD (4th gear) and you romp it, it will down shift and disengage the lockup. There's a balance there when you adjust the TV cable. Too little and the shifts are soft, the fluid pressure is lower (not good generally), and no kickdown on harder throttle use. Too much or too tight on the cable and the shift kit makes the shifts harder and later. When first making trial and error adjustments, it was scratching the tires when it would shift into 2nd even under lighter throttle use. So the shift points for me have been set based on that balancing act of good response when hitting it hard, not too hard of shifts under normal throttle use, and kickdown when wanted/needed - all coupled with my shift kit and higher RPM stall torque converter.
You made the comment about the lockup occurring "between 3rd and 4th gears". In the 700R4, the lockup won't occur until you are in 4th gear due to how the lockup solenoid is wired. The +12 comes in from the external connector (through a manually operated switch or the brake light switch as in my case). But the ground for the solenoid is internal to the Transmission and is operated when the tranny shifts in/out of fourth gear. So as long as the +12 is there, shifting into 4th grounds and activates the solenoid and shifting back out of 4th disconnects the ground and turns the solenoid back off. Now you can add an externally controlled ground via the eternal connector and then use that lock it up at any time you want (manual switch, external tranny controller, etc).
I thought about the GPS speedo with my gauges, but decided against it for two reasons: (1) Additional cost for the GPS sensor since it was not included in the kit. The existing pulse sensor was already included and ready to go and already fit the Dana 300 connector; and (2) mounting location for the GPS sensor. Research indicated it wouldn't work well mounted under the dash or hood. It needed to be mounted on top of the dash or somewhere more obtrusive where it could get reliable satellite signal. I didn't want that mounted out visible somewhere. I've had no issues with the pulse sensor and it works just fine.
So, added cost and antenna location concerns steered you away from the GPS style. I hear you. Thanks for your input.
SpeedHut includes the GPS sensor
Mounted mine (actually just pulled the cover and laid it up in there) under the cowl vent in front of the windshield...works like a charm
Might be an option for your Dakotas if you choose to go that route
Yes, they do. They are putting together a special kit for me, not cheap. What”d you do about the abandoned cable connection at the Transfer Case
Left the connector on...cut the cable off
I was swapping the tc anyway
Can't see that it would hurt anything, though
Just worried about oil leaking, that’s it.
....and the programming is super simple
Got it. Thank you all.
Another "dead" link. Please do a search for The New Gauge Page
I have no control of other websites dead links. What happens is that they change the URL or a page and do not create the appropriate direct. Sorry...
Which brand is not from overseas? only found 3 replacement brands; Dakota ( not quite ready to spend that much), Omix-Ada, and Crown
SpeedHut, not cheap but way less than Dakota Digital. I tried 4 from omix/crown all were JUNK! were not calibrated. And yes my jeep had the right drive gear.
I decided on this gauge arrangement. Time to fabricate the boxed mounting panel. It will go directly behind the steering wheel. We’ll see how it goes. It will be TIG welded using 2mm thick aluminum.
A CJ with gauges right in front of the driver? Weird, right? I'm so used to looking at the center of the dash that I'd be lost looking somewhere else for my gauges. :)
Got tired of doing just that, TS. Shouldn’t be too long before I get used to it. So, what to do with the emty hole in the middle of the dash is now the dilemma. I’ll probably mount a giant clock with Roman numerals, or stick a softball signed by a pro.
Mount a giant speaker. :chug:
Or maybe a tablet.
Nice ! Looking real sharp.
Mocked.
I agree, CJ. I think it’s a go. Thank you.
