HELP Removing Fan Knob on Dash
Schlipco
Midwest
'84 CJ7 Laredo
'82 CJ7 Limited
REALLY having trouble finding the slot on the fan switch saft to release the knob. Any suggestions....Have spent most of the morning on this. Thanks.
I think the fan switch does have a release while the cables do not. I will not swear to the 80s but the 77 has a release you push from the back, I think. I will take a look when the sun comes up hopefully before you have at it with a hammer and chisel.:D
Yeah....There is suppse to be a notch on the underneath side of the fan knob [which I have been able to locate] that a flat blade screwdriver can be used to disengage a spring that while pulling the knob it will come off.
I am not sure if the area where the slot is was damaged or if I have damaged it or if it is just stubborn, but I cannot get it to release.
are you trying to pull it out away from the shaft??:cool:
Yes and finally got it. Damaged release. Thank you for the response.
