help with year I.D.
help with year I.D.
jeepboy45
Old Time Jeeper
Altamonte Springs, Florida
1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
is the Jeep still around ?
post the VIN number if possible
based on the color of the Jeep, my guess is 1985 or 1986
No, several years ago I pulled the engine from a guys jeep in south orlando...
Never saw the guy, or his jeep before or since...
It might have been a craigslist ad... LONG GONE
engine build code then
tag attached to pass side valve cover
only other method I know....
I think, by the tag, it could be a 1974..??
Could the pics be of a model from back then.???
tag says 711N17
by this site:
amc valve cover id
well, the code can repeat....
from the later manual it decodes:
7 = 1987
11 = November
N = V8 360 8.25 to 1 compression ratio, 2BBl carb
17 = 17th day of the month
the vehicle pictured is from the mid 80s, could even be an 87.
definetly not 1974 vintage
7 = 1987
11 = November
Thanks Hagar... appreciate the help..
Like I said, this isnt life or death... I'd just like to know when getting parts, and for general knowledge. Parts should be the same for most years, but .................................
It is at least an '84 as that is when the "Grand" name got attached to differentiate it from the XJ-based version. Previous loaded Wagoneers carried the "Limited" tag. I'd say you are safe with saying it is an '87 from the numbers you provided.
thanks incommando..!
its good to know
