Here's my new project -(pics) with question
cwiehle0
Stillman Valley, IL
86 CJ7
07 Commander,
06 Mazda
Since your running the HEI it sounds like you have every thing that you need.. did you get the HEI form E-bay?? if so you may want to consider taking it and your old distributor to a shop and have the gears swapped. Seems like a new distributor gear mixed with and old cam gear tends to destroy it self pretty quickly. Ideally you would change both gears to a good quality matched set from some place like bulltear but that means removing all the parts from the front of the engine. Also dont forget to run a vacuum line for your advance and cap off all the other vacuum ports on the carb. I tried the hose and bolt method to make cheap quick plugs and mine ran like poop until I got good caps on it.
Did you get the adapter plate for the carb to intake??
Sorry but all the small problems I had with mine just came flooding back
I cant tell from the pic but do you have auto or manual.. if its a auto the bracket for the kick down will need to get raised. I used a few washers to raise mine up to the right height.
Unless the guy you bought it off of modified it (or mine was just an oddball) you wont beable to hook up your throttle linkage to the 2100..
#1 the hole in the rod will be on the wrong side
#2 it will want to pull the ball part straight down and will bind up. I was able to remove the plate the ball hooked to on my stock carb and modify it to to solve both problems.. if you find out that you have the same issue let me know and I can take pics of mine to show you better.. was really easy.
The pic of the valve cover isnt the best. can you take one of the valve cover off?? or a better closer pic of it the broken bolts?
Thanks for the tips and yes the adapter plate is supposed to be included.
Chris, is that a wrangler tub your putting on ? Cant quite make out the images ?
It is a Wrangler tub, and no I am not putting it on. It is pretty rotted underneath and I already went through that with my chevelle so I am going to look for something more solid or a fiberglass tub. If I do buy a Wrangler tub I and going to use CJ7 grill and fenders.
Thanks For the tips. I'm gonna try and get the valve cover off and see what's going on. I'll shoot a pic if I remember.
Thanks Chris
    Best for votes
    on specific items
