How close is too close?
billyocup
- Arnold, CA
- 75 CJ5 304V8 T15 D20 D44 D30 2 1/2" lift, 05 Victory Kingpin, 2011 GMC Sierra 3500 Diesel 4x4
I'm trying to get the in-frame Hedman headers mounted - 75 CJ5 - AMC 304 V8. I've run into some clearance issues that I'm slowly working through. On the drivers side I've got to re-route the brake and fuel lines. How far away from the header is adequate? On the passenger side, I've cut the end of the terminal on the starter off and the bolt on the spring mount to get the header to slide in. The header is now clear of the starter by about 1/2", but is still up against the nut on the spring mount. I can probably dent the header tube slightly to gain clearance from the nut, but it's a nylok nut and I'm concerned about melting the nylon in the nut.
Anyone have any experience with in-frame headers or any suggestions?
Thanks, Bill
Thanks, Bill
