How to fix question: 1980 CJ7 Renegade 4.2L Oil Leak from rear of pressure gauge
jdcaples
Old Time Jeeper
- Media
- 1
- Seattle, WA
- J0M93ECxxxx
J - Jeep
0 - Year 1980
M - 1980: 4-speed Manual
93 -Inches of Wheelbase?
E - 4150# GVW
C - 6 Cyl, 258 CID, 2 Bbl
Dana 300, SR-4, stock and rusting; I'm the fourth owner.
I noticed some engine oil dripping from behind the dashboard on to the passenger foot well.
There also a collection of engine oil behind the gauge's glass, at the 6 o'clock position.
Is this a common problem?
Since there's a small, plastic, hollow tube coming off the engine mounted sending unit, I figure it's a classic mechanical gauge with some power for a integrated bulb for illumination.
The engine mounted sending unit was moist with oil, but the tube was dry.
I tightened down the locking nut/collar on the sending unit (10mm wrench) and that's taken care of the engine side weeping.
I spent about an hour searching for a write up or how-to covering removing the gauge from the dash but came up lacking.
Which fasteners do I need to remove to access back of the gauge?
Is this going to be a simple, "make the connection snug" operation, or should I plan to replace the gauge?
I see torx-head fasteners on the outboard sides of the dashboard, close to the A-pillars.
Do I need remove the far bolts on either side of the dash to make some working room, or just crawl under the dash and start removing fasteners in the general vicinity?
I'd rather not guess.
Any hints appreciated. If there's a write up I missed, I'd be grateful for a thread link.
-Jon
-Jon
