I need a good source for stereo/speaker box info
Manhattan
Atlanta
1981 CJ-8: SBC, SM465, D300, 4.5" R.E. Extreme, 35" BFG MTs, 20/30 with 4.56 Gears, Detroits F&R, Moser/Warn axles, XworX Full Cage
If you have room behind the seat and the amp is really only for the subs. I would build a box, but design it to sink the amp into it flush. Like a box with 3" thick box outside it. Then cut out an area and sink your amp into it. You can even put a fan that pushes air across.
That way you can lift it all out at once, but it would not look like crud with an amp screwed to the back or side of it and wires hanging off.
Interior Dash Pad
