Build Thread IAFFCJ Beginning of my build (Pic Heavy)
- Featured
- 3
- Media
- 881
- Resources
- 193
- Solutions
- 56
- Central FL
A 120v welder can be tough to deal with - it has serious limitations...~~~were done with a Craftsman 115v mig welder~~~
As you have little penetration, that tells me the wire is still feeding too fast for the amp level. You need to slow down and let the wire fill as you burn in. It's a tough ratio to learn, but practice will help immensely.
Now, that being said - I have never used flux core so I could be way off! I took classes on TIG and just piddled (is that a word?) with Mig.
The best advice I can give you is that if the weld lays on the surface, you either do not have enough heat, are traveling too fast, don't have enough wire speed, too much wire speed for the movement or just about any combination of the above.
I know that really doesn't help, but getting it right takes allot of practice and time!
