If you 3 link a CJ front axle with coilovers, do you need high steer?
I wasnt too worried about the angle from the pitman arm, i was going to keep my jeep pretty low, a dropped pitman arm would probably work fine for a while , then , as time permits...go high steer
As far as I know the only real benefit from high steer is
1. Helps clear the spring pack in SOA set ups
2. Help prevent bump steer and death wobble due to extreme steering link angle
So if your 3 linking and a drop pitman arm works fine you wouldn't need the high steer set up.
