Installing New Voltmeter
Shazam
North Carolina
1979 CJ-5 Renegade with '74 304 V8 & Edelbrock manifold & carb, Heddman headers & sidepipes, T-150 3 speed, Dana 20, Dana 30, AMC 20
Hi guys. Getting ready to add a new Sunpro voltmeter and it looks too simple for someone like me. Is it really as easy and running a wire to the + battery and one to the negative? And where should the bulb be connected? Remember I'm new to this so dummy it down for me :)
Also, I hear about the importance of a good ground. Can someone tell me where to find one on a 1979 CJ5 - or at least fill me in a little more on what makes a good one?
Thank you!
If your connections for your factory gauge is still there you can use them, they will slide right on to the studs on the back labeled + -, and no extra wiring involved (that's what I used). Or yeah you can, just run a pos wire to a ign switched 12v source, then ground, I would run a wire to the neg. Side of the batt for that, but you might get away with just grounding it to the dash.
DROOOID 2
$75.00
  37.5%
