Intake Manafold Holes
This is my first post. I look forward to learning from all of you!
A quick question. I recently purchased a 86 CJ7 . The engine was running rough, is a pain to start (starter fluid gets it going) and you would need to keep a higher rpm otherwise it would putter out.
As i stared cleaning up the engine, it became very clear that there are 3 threaded holes in the intake manifold that were left WIDE open by the previous owner - clearly some sensor was removed, never replaced and is allowing air to flow in downstream of the carb.
Has anyone ever plugged these up? I can literally stick a screwdriver into the manafold. Could this be the cause of my issues?
