Is this a mistake or is it "Painless"
- Springfield, Missouri-U.S.A. Earth
- '85 CJ-7, 258/4.2L 6cyl. Bought new in 1985. Full cage, Warn 8274 winch, Ford 9" rear, front/rear Detroit Lockers w/4:88 R&P. T-5 tranny and 4:1 t'case. 33X12.50-15 BFG/AT, MSD ign, on board air---
Okay, after looking at all the options, and I really looked I went with the Painless wiring loom from Summit. I found this one thing to be disappointing, the website shows that customizing is available, NOT!
All n all knowing the wiring modifications that have been done there shouldn't be any real problems working with this kit. Now to find relays sold in bulk. I'm at needing 30 and counting. Since each relay will need a fuse that's 30 weather proof fuse blocks. Man this will be expensive. Lets see, I'll need to run hot wires to make the switched hot wire hot that another ..........![]()
You only need 1 relay for the headlight circuit. Look at circuit breakers or fuse panels made for boats.
I would also use a relay for the heater blower motor and windshield wiper.
What are you run'n for headlights? I run the Hella conversions with higher output bulbs. Much less current used than with the OEM type.
