It's a Gusher!!
It's a Gusher!!
MDJEEPER
1986 Jeep CJ
Guys,
So, I replaced my water pump and flushed the cooling system in my Jeep. Apparently, I did too good of a job because once I fired it back up the radiator decided to pop a pin hole leak right by the upper radiator hose (see picture). It's not a big leak, but it's definitely a leak! Talk about defeat snatched from the jaws of victory!!! :bang:
Is there any way I can plug this leak for awhile until I can get approval from "The Boss" to spend yet more $$ for a new radiator?? And no, I don't have a welder...
JB Weld?
Epoxy?
Bueller? Bueller??
Thanks!
Guys,
JB Weld?
Epoxy?
Bueller? Bueller??
Thanks!
Can you solder? I cant remember 100% but i think you need a resin core based solder and it will seal it, you could google on what type of solder you would need.
Don't even think about trying to solder it!! That is one truly loosing proposition.
Pay a pro and check his references, A radiator can turn into a story to be told around the fire for the next life time. JB gets soft when it is hot and it will make it difficult to fix later.
Let it run for a while and see if it will heal up, yes it can happen if the hole isn't too big and you still have enough silt in the coolant. Stop leak works, it has to be your decision . I only use it in emergencies and the biggest problem I have had is it seems to reduce the capacity of the heater coil.:cool:
Seeing as how I just flushed and changed out the antifreeze, do you think there could be sufficent silt to plug it up again?
I do have a large soldering gun and solder. I don't have the flux, but can get some. But what about IO's point that soldering is a bad idea??
I have to respectfully disagree with IO on this one. I think this is something you can successfully repair yourself.
I do agree with everything else IO says though, JB weld never works on a radiator. Bar's Leaks and Stop Leak tend to plug up your heater core. And there is a very slim posibility that it'll heal itself.
While we're on this subject...If the repair does not work, what type of replacement radiator is recommended? Two row vs. three row? Metal tanks vs. plastic?? Copper vs. Aluminium???
Looking online there are too many choices, with prices ranging from about $140 to over $300!!
they sell this stuff called liquid aluminum at the autostores. I had a whole bunch of little likes in my radiator and I poured some of that stuff in and it seems to be holding I haven't found any wet spots since I used it and do not have any over heating issues.
with a small pin hole leak, why would you replace the entire radiator? I just had mine rebuilt by a professional shop.
He flushed it, soldered a leak in the lower tank, painted it and straightened out the fins so it looks like brand new.
Total out the door? about $52.00.
It depends. What do you do with your CJ? Daily driver, weekend wheeler, mud racing, rock crawling? I would say stock replacement is good for daily driver and weekend wheeler. Unless you're running a big lift and big tires and DD it, would you need to upgrade to a bigger (3 row) radiator. And if you're mud running or rock crawling then you need to look in to all aluminum 3 core super sexy $300 plus radiator.
So, based upon what your saying, I'm right that the stock radiator is a 2 row, correct?
Thats what I would do.
Yes, I'm almost positive that the stock radiators where 2 row.
mylittlecj5 makes a very valid point, if this isn't anything you've ever tried before and are a little hesitant to try, find a local radiator repair shop and pay the $50(ish) to have it repaired. Beats shelling out $AMC 150 or more for a brand new one and usually the repair shops works is warrantied for some amount of time. Just more food for thought...
or Baars stop leak! or K&W block seal. Works everytime. Just pour it in the radiator. :)
