It's a Gusher!!
Buuushman
- Media
- 7
- Kihei, Hawaii
- 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Ya, just keep using stopleak every time you drip a little water, instead of fixing the problem, just like the P.O. of my jeep did, and when it comes time for a new cam or anything else that requires you to drain the block you can spend an hour or so with a hammer and screwdriver trying to clear the drain holes of the 1/2" of cemented stopleak crud that has coated the inside of your block.
The ONLY use for that stuff is emergency repair when there are no other options. Unless you really don't like your motor, that is.
Bushman
Bushman
project, I soldered a LOT of radiator holes with perfect results.
