JB Fabrication Aux. idle control
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
A few months ago I purchased one of JB's Aux. idle controls. Now it's time to make it work. I chose the stick as the mounting location similar to the location the bicycle throttles are mounted.
So, it's mounted, the cable runs through a hole in the floor with the proper grommet for the hole. JB gives you LOTs of cable to deal with and a nice little package with a cable stop and some bead chain to connect the cable to the carburetor. I can see the cable needs to be cut and mounted. Sure I can fumble around and finally get it mounted, but if you have done an install your proud of and some pictures I would be happy to see'em. If you'd like to author a story of the install, wow would you be a saint. If not I guess I'll have to do it myself .... sainthood would look good on my pear like body....
