Jeep drivetrain
Would a 318 or 360 dodge engine bolt up to a jeep/mopar 727 transmission in a 1970 jeep wagoneer.
no it won't, jeep had it's own bolt pattern
The AMC I6 and V8 share the same bolt pattern so if you want to go to a V8 without adaptors I would look in that direction but I would check the bolt pattern of your transmission just to be sure as the 1970 Waggy V8 was a Buick 350; not sure what Jeep did to mix and match. Just remember the AMC v8s are externally balanced so you need to have the proper flex plate for the specific engine.
If the wagon has a AMC 258 i6 / 4.2l /t-999 it was swapped in so the AMC 304 /360/401 would be an ideal V8 for your setup.
FYI, the factory 6 cyl/auto offered in a 70 wagon was the OHC 230/Borg-Warner AS-8F
$70.00
  35.0%
