Jimbos YJ/CJ build
Jimbos76cj
Full Time Jeeper
- St.Cloud FL
- 83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!!
Ask me about my head light upgrade harness!!!
Ive decided to ditch my CJ6 project mud truck and concentrate on my YJ build. Heres a little back story on this thing.
PO rolled in at a high rate of speed and suffered severe spinal trauma. ended up listing it as having a newly rebuilt motor, ax-15, 231 with SYE and TW CV shaft. Me and him messaged back and forth about it for a few weeks but I couldnt come up with the $600 he wanted for it. I mention the jeep to a buddy who was looking for a ax15 and he decided to buy it and let me have every thing except the trans and T/C which at the time didnt seem to be to bad of a deal. Got her home and she looked like this
Pulled the drive train, swapped the trans and TC into my buddies jeep and it ended up being a nightmare.. not the swap but the trans was shot and the 231 quickly pooped the bed after installed. but thats a whole other story.
So when I got looking at the pile of left over good parts I found out that the lift springs were bent, rear axle shaped like a U and the frame was bent. So I ended up with a good grill, steering column, motor (after seeing the condition of the "new trans" I doubted the motor) and radiator.
A quick look on the intraweb scored me a solid frame and a tub with a family style roll bar.
A buddy donated front and rear seat, and 2.5" lift springs. The PO of the wrecked jeep gave me a NIB set of 1" body mounts.
I nabbed a set of 4:10 geared axles and If I remember correctly the front in the high pinion 30
I decided to try out the duplicolor paint system they sell and to stick with the red thats on the new tub since the inside is already rhino lined with red rhino liner. Heres the dash and grill
The system work pretty well.. I like the results. So I hit CL looking for a trans and come up with a external ax-15 that according to the PO is shot. Grinds most gears and wont stay in some. I pick it up for $150 which seems lit a great deal. I drop it off to my neighbor for a rebuild and when he gets into it he finds that it needs synchros, and 2 bearings.. the gears all looked in great shape and the popping out of gear was due to a recent rebuild the PO did and never tightened the detent screws. so for less then $400 I got a great shape ax-15
Then came time to look into the motor.. after seeing what a POS the trans and T-case were I figured the motor was poop also. I was wrong!!
Not a bit of sludge.. every thing looks brand new!
