Junkyard Tuned Port Injection For AMC 360
ThisGuyUKnow
Full Time Jeeper
- Featured
- 2
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
So I have been flirting with this for several years and never seem to have a jeep long enough with the 360 to do it. I am in the process of acquiring an 85 CJ7 Laredo with a freshly rebuilt AMC 360 and I have decided that this will be the base and recipient of this experiment.
People have been doing junkyard throttle body injection (TBI) conversions on the 360s for years and this is a very similar process. For anyone who does not know TBI is computer controlled fuel injection that still uses a wet intake like the carb. This will be a Tuned Port Injection (TPI) which will actually inject the fuel to the intake runner, just like Multi Port Injection in modern vehicles except TPI is batch fired and MultiPort generally fires individually per cylinder.
So first off edlebrock actually makes an AMC v8 MPFI kit for a huge price of about 3000+ dollars. Howell and other companies make bolt on TBI kits for about 1000+ dollars. These are bolt on, come with instructions, and are definitely the way to go if you have the cash or do not have strong wiring abilities. My conversion is going run me about 800-1000 dollars and most of that was spent years ago when i first acquired the modded intake. The second big expense was the wiring harness.
Alright so the there are a two major hold hurtles for converting to TPI first off, unlike the AMC 6 Cyl which got redesigned to the 4.0 with MPFI, AMC v8s never saw fuel injection in production so no factory compatible Multiport intake exists for the v8 (not counting the edlebrock kit which appears to be a modified torker). So google searches and trolling through lots of threads alot of people who know way more than me when it comes to engine performance all seem to point to a single plane 4bb intake could be modified to accept fuel rails and injectors. This is exactly what it appears Edlebrock had done in their kit. Two intakes id'd as potential donors for such a project that were suggested were the edle torker and the holley street dominator. More of these internet "experts" seemed to lean towards the torker for whatever reason. I am not an engine builder nor pretend to understand the mechanics involved with getting proper atomization of fuel and air flow but basically once converted the intake would cease to be "wet" intake and the runners would serve only to supply air and the fuel would be directly injected into the intake runners on the head.
I have had the Modded intake for probably close to 3 years now. I ended up cheating a little on the intake. I did not acquire one and have a builder mod it to my specs. Instead, at the time, there was a guy in GA that ran a business called CustomeEFIs specializing in producing FI for AMC jeeps. The guy temporarily got into TPIs before he went under and I got the intake from a member on IFSJA.org who had started the project but due issues gave up on it. The intake is a holley street dominator and the throttle body in it is also a holley (I have not id'd the TB model yet) and the fuel rails are custom. The injectors and sensors are all based off a 90-92 Corvette 350 harness. I'll hit these in detail later but a good number of the sensors required for the TPI computer are actually located in the intake.
Another issue is that one of the major benefits of any FI system is the electronic spark advance. The AMC v8s use a mechanical advance and since they never made a FI v8 there is no boltin electronic distributor. I will have to either mod an HEI or stock distributor to lock out the mechanical advance and convert to spark control. The TBI pioneers have long since found a way to do this and I am hoping that when I get that far that the process will be similar. I will use the TBI write ups as a guide on that one.
I ended up joining a corvette forum and trolling around on there until a 90-92 vette showed up as a complete part out. I contacted the guy and we worked out a deal for 200 bucks he would carefully extract both the engine harness and the underdash harness with no cutting (with the exception of where the harness enters the doors, don't think there is anything potentially important in the doors) What I ended up with was this:
the birds nest at by the bike jack is the interior harness and very dense. The wrapped harness is the engine side and less intimidating looking... well slightly. I stretched it out around the intake to kinda see where everything ends up.
