Just Bought 85 Laredo !
Cool.. In the next few days I will clean up the bottom side and take some pics. Maybe you can tell me how to tighten things up.. As far as the noises are concerned they are really hard to describe but here it goes..
When you accelerate hard there is a scraping noise coming from the rear, at first I thought it was the body scrubbing the tires somewhere since it only happens in 1st gear under hard acceleration when the rear "sits" down.. It sounds like something that is " spinning " but I cant find any wear marks on bottom side.. keep in mind it only last for a second or two.
Any Ideas???
As far as the front axle is concerned I will rebuild/repack the hubs and take a look at everything then.. since I just bought it this is something that I should do anyway.. The PO did no maintence other than oil changes..
By the way the front drive shaft is made out of square tubing.... Is this right ??? The rear shaft looks original... (round)
