Body Leaking Top
Body Leaking Top
Super8mm
Silver Supporter
Bronze Supporter
Grapevine, TX
1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
Good luck, hopefully someone has an answer, I was never ever able to completely seal anything with a soft top older than 86
Your first image showing the hinge pin is the adjustment. Loosening that nut then allows the hinge pin to slide side to side (in or out of the door) the width of that slotted hole.
I did find another bolt hidden under the material that folded around the frame. I loosened it and raised up on the back edge of the door and tightened the bolts and that helped a bit. Just don't tell my surgeon that or he will have me wearing my brace 24-7 again.
Now that the gap is down to about the size of a pea I think I will loosed the windshield clamps and use my ratchet straps again and see if I can pull the windshield back a bit more????
