Misc. Led Upgrade issue
Jadonal
Donator
Milton
1984 Jeep CJ7 Renegade
You need electronic flashers, one polarity reverser, and two resistors. Check here for how I did mine: LED Conversion
I installed the electronic flashers. And to clarify you used 100 ohm resistors on the negative and positive wires behind the front turn signal? For a total of four resistors? Also does it matter what type of resistor so long as its 100 ohms.
I only used two resistors, one on each side behind the front turn signals connected between the blinker wires and ground. No connection to the marker light wires. So just one resistor on each front turn signal for a total of two resistors. I used 1/4 watt 100 ohm resistors soldered in place. I scratched the surface of the blinker housings to prepare a textured place for the solder to grab as the ground connection. Of course you could solder or splice in to any ground wire source for this. Then solder the other side of the resistor to the blinker wire going to the plug.
$20.00
  10.0%
