Lift kit help and advice for CJ-7
Ya I only did the 2.5inch as well.(less driveshaft problems) I figure if I need ,I can add a 2inch body lift if I want to go up to 33s.
Go with the lift, No Shackles. I have stock springs and a 2" body lift and running 33's with no problems. Upgrade shackles but dont put lift shackles. To much lateral strain. will cause springs to walk to much. Shakle reversal then you could. this is my $.02. hope it helps....
