little help
killnbusiness
- Weatherford, Ok
- 78 CJ5 258 ci 3spd 3" lift 33x12.5 BF mudterrains,
82 CJ7 AMC 360 4spd 6" lift 35x12.5 BF MT's spray on liner inside outside underneath and frame one piece rear axles Spartan lockers
87 CJ7, 258 ci, all stock, 31x12.5 BF AT.
Hey everyone I have a slight problem. I have an 82 CJ7 that the PO installed an AMC 360 and a T-176 . While putting the jeep back together from a frame off restore I noticed that linkage for the clutch is hitting the frame. The part that is hitting the frame is the tube that is in between the rod from the pedal and the clutch. It bolts to the bell housing with two bolts and has an adjustable link for clutch play. Sorry new here and don't know how to add pics just yet. Has anyone come across this issue yet, and what have you done to solve it? Thanks
