Loose flywheel
Triman
- Media
- 14
- Birmingham, AL
- '86 CJ 7 black primer color
Automatic on the column
258 engine for now
TC??
DIFF?
Ok guys, pretty sure I did a bonehead thing after a successful AMC 258 i6 / 4.2l automatic rebuild. I've been careful to take it easy to be sure the timing and fuel mix is right...But I crank the motor this am to get ready to work on the front brake pads and hear a pretty crappy sound from the motor that sounds like rocks coming from the valve cover. I look/listen/Google
closer and start to wonder how tight I bolted the flywheel to the engine. I remember being quite destracted in the garage with a four year old when getting the bolts set and never got the correct torque on the bolts. I think the specs call for 80lb, but I don't think Im close to that at all and wonder if they might be working loose.
So the question is...Im thinking I can refrain from pulling the entire motor apart if I pull the front fan off and slide the motor forward to make room for a torque wrench to tighten those bolts. Anyone try this before?
If not, it might be time to break out the camera, im reading lots of sites where people have had this happen, but not sure where to start other than pulling the complete motor...
Thanks in advance for the help.
