master cylinder help
so you guys are looking for the "condom" the shaft fits through??no joke. if i have to buy a new master cylinder, this will be the most expensive gasket ever!
no, I'm looking for the rubber piece that goes into the lid.
If we do... we'll need to be sure to pick one that's compatible with the brake types we've got... drums all around (unless we upgrade that, too).
The MC is an iron two-compartment MC with both chambers the same size, rounded at both ends. I'll try & get a photo in the morning when it's a little brighter out.
It is obvious , once again, that you know more about this than I do. are the back pressure valves, you speak of, a form of proportioning valve or is this something else??When I upgrade my brake system I bought thr Ford truck MC and put the back presure valves I wanted in either chamber
after pondering this for a bit it occurred to me that if the gasket in the lid is shot, how far behind could the rest of the rubber in the master be.:dunno:
It is obvious , once again, that you know more about this than I do. are the back pressure valves, you speak of, a form of proportioning valve or is this something else??![]()
check vales, back pressure vales etc, kinda the same name for the same thing.There actually is a little valve in some master cylinders that holds a small amount of pressure on disk brakes to keep 'em seated against the rotor. It's almost always on the front chamber, if it's there at all. Usually those are unequal-chamber master cylinders, though, 'cause disk brakes and drum brakes don't need the same amount of reserve fluid.
In this case, it's pretty moot unless we do the disk-brake upgrade for the front. If we do that, we hafta' switch to a different master cylinder & add a proportioning valve.
