Mpg?
Rescue Diver
Full Time Jeeper
- Kansas City
- 1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
Sounds like you've got the right carb for it.I took my Holley 670 truck avenger off two weeks ago to go back to my Edelbrock 600 cfm 1405 carb. I have a full blown tune kit for that carb so I wanted to mess around with it. The holley allready had the heaviest spring on it for the secondaries but the best I could manage was 10-12MPG. The Edelbrock bumped me up to 13.9mpg for one tank and then 12.5 on my second tank but I drove it harder the second time. I want to see what I get with just the primaries since they are smaller more like a Qjet spreadbore. If I can get 14mpg and then switch to a 5 speed in my Scrambler to bump me up some more then I will be fine with that. When I hit the trails I can hook up the secondaries for the horsepower and more fun times. I understand what you say about the carb sizes. I am pretty decent at tuning them but it takes time and patience to get it right.
What's your total ignition timing set at? If you can bring on a little more mechanical advance in the mid range RPMs without it pinging, you'll bring up your MPG. Incorrect timing(not enough advance) can easily cost you several miles per gallon.
Mine went up noticably when I re-tuned my advance a couple weeks ago.
