MSD 6a wiring ?
GS1200
Installing the MSD ignition control module, the wiring diagram in the team rush thread shows the tach wire not connected, do you just hook that up to the green tach wire from the old coil connection? I put in the Blaster coil at the same time, (free with the MSD 6a from summit).
the ground cable from the battery to the engine was cracked, so I decided to replace it, and found that the small ground wire to the firewall, the bolt has a nut on the inside, which of course is now spinning, and I cant reach it. Anyway to get to it without taking the whole dash off?? Whos bright idea was that??
