My 76 CJ5 restoration
CJbrodey
NE Tn.
'76 CJ-5, 304, T-150, D20, D30, D44.
Hello everyone.
This is my first post here and since I am going to finally try and finish
my CJ5 project, this seems like a good place to be.
About 5 years ago, I decided to restore my '76 CJ5 .
I removed everything from the frame except the motor, tranny & tranfercase. I scraped
& painted the frame and was glad that it was a boxed frame with no rust.
I replaced the spring bushings, and shackles, and did an SOA conversion w/ a new 4"drop pitman, spring
perches and u bolts, and lowered the Transfer Case 1". The rear driveshaft was shortened, and
new heavy duty Ujoints were installed.
I replaced the brakes, wheel cylinders and lines, and relocated the rear shocks. I then installed
new inframe headers w/ new flowmasters and exhaust, and also replaced the tie rods and ends.
The body was badly rusted in the front floors so I cut out all the rust and welded a 1" square tubing
frame for both sides and used some aluminum interstate signs to re-skin the floor. I then fabricated a
steel seat frame and welded it to the 1" sq. tubing, and rhinolined the tub.
After mounting the tub (which was alot heavier from the reinforcing) I painted it Matrix Gloss Black w/ clear.
I installed the racing buckets, 5 point harnesses, and the 6 point rollcage.
After I got everything installed and was ready to start the motor, I was amazed to hear it running again. I got in
and did a test drive down the road and it handled great! My rear pinion angle was good,
and the front end adjustments were right on.
Later that day, the motor started to act up. It wouldnt idle, and it started backfiring and wasnt running right. So I
decided to replace the distributor, coil, wires, plugs and re-time the ignition. (Its a Prestolite ign.)
It was Still acting up, so I replaced the fuel pump and the carburetor.
Well, I decided to ask around and was told that quite possibly when I re installed the wiring, I might have inadvertantly shortened the resistive wire and burned up the ignition control module.
Since the only thing that hadn't been replaced on the jeep was the wiring harness, I ordered a new Painless harness, and it had a ceramic firewall type resistor. I installed it and have everything hooked up, and all the LED's are working
but I havent changed the ignition control mod yet. I really need a better ignition, but right now I want to get the crappy prestolite working.
I havent done anything to the jeep in almost 2 years now, but after washing all the dust off the jeep and seeing her shine again,
I have decided to resurrect the restoration and finally finish this project.
Nice way to join the group with a great first post and a sweet Jeep. Welcome to the site.
Welcome! Nice pics. Good story. I hope you get it done soon.:ww:
Thanx for the kind words and encouragement. I had kinda lost interest in finishing this project, but lately I am getting the jeep bug again and I really want & need to finish what I started.
Today I cleaned 2 years worth of leaves out of it, and removed the seats, console, and roll cage.
I plan on next removing part the front-top section of the wheel-well's right at the bend behind the seats, and "flattening" the corner's to make about 4 more inches of seat travel.
I'm also gonna remove the 2 rear horizontal bars (pic 4) on the roll cage, and re-bend 2 more. From this; ______ , to this;\__________/.
Hopefully this will make it possible to get in and out of the jeep a heck of alot better.
I will post pics and keep you all up to date.
Again thanks, glad to be here.:chug:
Nice work! Looks like you may have run into a similar problem that I had as your seats look really high in there mount? could be the camera angle but to me looks like even a short person would have terrible head room.
I installed mastercraft seats in my cj on the factory brackets and they were so high my wifes feet did not touch the floor when seated! a day later after fabricating new brackets her feet are back on the floor and can look straight out the windsheild again..all is good.:).
yeah, I'm gonna take about 2" out of the seat frame also. I'm only 5'6", and at the present its tight even for me!
I have decided to do away with the diamondplate dash, Im going to fab one out of a nice piece of wood, and aluminum. As soon as I find my camera software I will post pics of the seat frame/rollcage mods, and the dash.
Fantastic CJ! Thanks for joining. :)
Thank you CJ. My pleasure. Since joining and checking out all the threads at this cool as heck site, it has re-kindled my desire to get back to the jeep and get it running again.
As soon as I get the seats where I want them, I'll tackle the ignition and try to get it running. Oh, btw, do you suppose that electric fan you have for sale will fit my jeep?
