My garage build start. Winter project.
Kane
Full Time Jeeper
- Media
- 4
- Berlin, CT
- 1984 CJ-8 Restomod Scout axles 4 wheel disks, 258, ax15, D300.
Ahhh, finally I get to start building my new garage. Since I moved into my new house last October I haven’t had much of a chance to work on it mainly because it was full of
from the move in. I finally got it cleared out enough to start on the construction. First step is to get the walls insulated and then hang the drywall. I won’t be able to tape or paint until spring though unless I want to run a heater in there full time which I haven’t got that set up yet. We’ll see if I feel like doing that or not. Right now I am concerned with just the drywall so I can get everything else in place. I have some cool Jeep and motorcycle style painting I want to do on the walls though so it will look very cool when I am done.
This garage is much better than my last 20x20 set up I had. This one is 24x24 with 9 foot ceilings and it has a pull down staircase for the attic so I can store all the
up there. Plus the chimney is on the left wall which will be good for me putting an exhaust in for my propane heater.
So far these are my plans which will change 100 times I am sure:
And my killer Jeep thrown in for good measure.
from the move in. I finally got it cleared out enough to start on the construction. First step is to get the walls insulated and then hang the drywall. I won’t be able to tape or paint until spring though unless I want to run a heater in there full time which I haven’t got that set up yet. We’ll see if I feel like doing that or not. Right now I am concerned with just the drywall so I can get everything else in place. I have some cool Jeep and motorcycle style painting I want to do on the walls though so it will look very cool when I am done. This garage is much better than my last 20x20 set up I had. This one is 24x24 with 9 foot ceilings and it has a pull down staircase for the attic so I can store all the
up there. Plus the chimney is on the left wall which will be good for me putting an exhaust in for my propane heater. So far these are my plans which will change 100 times I am sure:
- Finish dry wall and insulation.
- Shelves are done.
- Install my air compressor in the attic and then install the air hose real on the ceiling.
- Install electric cord real on ceiling
- Install my fluorescent lamps throughout the ceiling.
- Install propane heater.
- Get the 220 volt line run into the garage for the welder.
- Tape then paint walls and ceiling.
- New garage doors and opener because the current ones suck. The door for my Jeep I plan on getting a taller 8 foot door and the shaft mounted opener. I am sick of scraping the door with my top when I drive in.
- Build a small storage rack for the metal for fabrication projects.
