My situation...Any words of wisdom....
gaberu
- Gilbert, AZ
- 1985 CJ7
258 w/2100
T5 w/Dana 300
Rubicon Express 2.5" lift
Hi everyone,
First time member. I was hoping for a little advice to a what would you do kind of scenario.
The situation: after taking off my heads and having them gone over at a machine shop, it ends up the reason for the coolant in my oil pan is because of a small crack around my #4 cylinder which I confirmed with a pressure test after I got my heads back and everything put back on.
So that puts me in a tough spot. There is an old guy who has a very reputable shop here in Tempe, Arizona called Hoppers Automotive been there for over 50 years and does a lot of work on Willys, CJ's, J20's and what not. Well he told me if I could tow my jeep there, he can find a replacement block, clean it, bore it, the whole 9 yards and put everything back on and have it up and running for around $3000. So my dilemma is does that sound like a fair deal first of all? And thats not to say I have $3000 buring a whole in my pocket; because I certianly dont. But it is what it is and I've put way to much blood, sweat and tears; oh yeah and money, to give it up on her now and cut my loses. So thankfully my wife whose the greatest
is on board in pulling together whatever we have to if that ends up being the route we need to take. And secondly being that I have never installed an entire engine, would another option be ordering a reman. engine online from ATK or some where else which is going to be a round $2000 when all is said and done; freight, tax, core etc. and putting it in myself? Only problem is aside from the technical piece, is that I've read probably reviews on at least 4 online engine houses, and its definitely hit or miss with regards to what you might end up getting with quality/workmanship and customer service.
And like I said, I've never done anything that in depth as to pulling an entire engine and dropping in another one. Though I have replaced and/or rebuilt almost everything myself with the help of a very dirty Jeep Service Manual, a Mosers rebuild manual and a Chiltons; new water pump, new rear main seal-when I discovered crack, new radiator, new suspension, rebuilt 2100, new timing chain, new fuel tank and lines, all new brake hardware, lines and components etc. etc - certainly learned alot.
Any words of wisdom and support would be greatly appreciated.
Thanks everyone.
is on board in pulling together whatever we have to if that ends up being the route we need to take. And secondly being that I have never installed an entire engine, would another option be ordering a reman. engine online from ATK or some where else which is going to be a round $2000 when all is said and done; freight, tax, core etc. and putting it in myself? Only problem is aside from the technical piece, is that I've read probably reviews on at least 4 online engine houses, and its definitely hit or miss with regards to what you might end up getting with quality/workmanship and customer service.And like I said, I've never done anything that in depth as to pulling an entire engine and dropping in another one. Though I have replaced and/or rebuilt almost everything myself with the help of a very dirty Jeep Service Manual, a Mosers rebuild manual and a Chiltons; new water pump, new rear main seal-when I discovered crack, new radiator, new suspension, rebuilt 2100, new timing chain, new fuel tank and lines, all new brake hardware, lines and components etc. etc - certainly learned alot.
Thanks everyone.
But it was priceless. Well I lost him 2 years ago. And after a year of composing myself, I started working on her last March, with a committed goal of getting her done in a year. Well low and behold 13 months later while doing the very last repair I needed to do; replacing the rms, I see a small line of coolant coming down the #4 cylinder wall.
that is an awesome accomplishment by any standard-and I am certainly up to the challenge and experience. My only concern is by sleeving it, how much time does that buy me. Do you know many people that have gone that route with worth while success? Granted I dont plan on rock crawling or anything that extreme, but I will definitely be hitting a trail or two where the lockers might have to be used. Most of all its for taking my wife and our 7 year old out in the back country and just having a good time.
