Need ideas on strange noise...
- Media
- 5
- Solutions
- 1
- Roanoke, Va
- '80 CJ-7, AMC 304, T177, Dana 300, Widetrack axles (D30 & AMC20) w/ 3.73 gearing, MSD ignition,
Ok - I have developed a strange noise that seems to combine a heavy squeak and an apparent “thumping”. In my mind it sounds as though I have a chunk of rubber door mat attached to my driveshaft and it’s whacking the skid plate. Now, that’s kinda sorta what it sounds like - as for frequency - it only does it in a hard left hand turn, as in 1st and 2nd speed hard left. May do it at higher speeds, but I don’t wanna till it - that’ll just cause more noises.
I have checked, in no particular order, steering box, steering shaft, tie rods, shocks and shock mounts, leaf springs and related hardware, skid plate, tranny mount, rear bumper hardware, tire carrier, body mounts, roll bar hardware, hard top, hood hinges, exhaust, radiator bolts, axle u bolts, lug nuts, rear axle retaking bolts, and seat risers. All are tight.
At first I discounted drivetrain due to it only appearing in a hard left turn. Straight travel forward and backward in 2 and 4 wheel drive never does it. Hard acceleration won’t do it. However, coasting thru the hard left rarely does which points to driveline. If a ring and pinion we’re going out I would think that would raise holy hell all the time, and ya can’t “ feel” it in either shifter....... and I would think s loose flywheel or pressure plate would cause a host of other issues.
To further add confusion, I do have a new squeak I think is related, and it is fairly constant. That one sounds like a rubber spring bushing - but they’re well greased.
Some as I have dry weather after work, I wanna drop one driveshaft at a time and see if it changes.
Any ideas??
Sent via my universal translator
Any ideas??
