Need ideas on strange noise...
Turning left or right transfers more weight of the vehicle to one side.
So if the noise is more prominent when turning left, wheel/axle bearings on the right side get more load.
Just something else to check for.
I thought I had it taken care of..... but it will still do it in a hard left turn under power..... as in turning hard left from a stop sign and accelerating. I'll see if I can record it .......
Sent from the tightening arms of Morpheus......
I would look at the engine and tranny mounts.
The PS engine mount has a know history of failure.
I would check the wheel bearings. I have heard wheel bearings make some weird sounds. The way you refer to it doing it on turns tells me it has to do with loading. Be sure and check inners and outers. Check the locking hubs while your there. I’ve Sean bad bearings take out hubs.
