Diff New gasket or something else?
Differentials
TBCJ5
South Carolina
'73 CJ5, 232/3.8L I6, Dana 30 front, Dana 40 rear, Dana Spicer 20 transfer case, 3 speed, fun.
Looks like the outer edge of the gasket is getting brittle and breaking off. Nothing to worry about unless it starts leaking. Not hard to replace if your inclined.
Might be a good time to see what is inside there.
If you do decide to replace it .... get some cheap bolts about 2 or 3 inches long ( one for each bolt on cover). Cut the heads off. After you have the surfaces clean, thread the headless bolts in hand tight, just enough so they don't wobble around. Take the gasket and fit over the headless bolts. Then the cover. Then take one headless bolt out at a time and install bolt. The headless bolts keep everything lined up until you tighten everything down.
