Newbie help - remove steering wheel 79 CJ5
ewerbeck
Florida
1979 CJ5 4.2L 258. Dana 20 T-Case, T150 3-speed manual trans. Dana 30 front. AMC 20 rear.
I am removing my dash in preparation for removing the tub.
I've unbolted everything i can find... but the steering wheel is still not coming loose, though there is some movement. Can someone give me a tip or two???? :confused: See below.
Don't think you qualify for an "idiot" label. Looks like you figured it out for yourself before anyone could chime in. Good luck with the resto!
Thanks. I assume that's my problem. I'll try to remove it tonight and report back.
The bolt definitely has to be removed. It may still be a chore to get the clamp to slide off. I ended up needing a spray can of "slick um" and a persuader to motivate mine to come off. Wedging the clamp open a bit will help with the removal and the install.
Thanks guys. Removing that bolt combined with a little prying apart of the clamp mixed with a little hammer action did it.
