O-Ring / flare return line for power steering
CJ jammin
Bellevue, Nebraska
96 Cherokee Sport, 4.0 HO, 3.5" lift, AFE CAI, SYE & 2Low transfer case conversions, double cardan drive shaft from a Grand Cherokee.
80 CJ7, 304 w/Edlebrock carb, Dana 300 TC, SR4 transmission, 4" spring lift up front, shackle lift on the rear. Hooker headers and Flowmaster exhaust. Hard top. Full cage. My new project.
Okay. My steering box has flare for the pressure hose connections on both the pump and gear box side and o-ring for both ends. Is this normal? Of course the replacement is an o-ring style. Can it be modded properly using a flaring tube?
Re: Power steering pressure hose
Flaring TOOL. is what I meant.
Actually, let me rephrase that. The return line hose has an o-ring connection on the gearbox end. And the pressure port doesn't look like a flare fitting inside. However, the pressure hose has flared ends and there was no leakage from either connection. So, I think I answered my own question. But, how do you be sure you get a hose with flared ends?
O ring connections are metric and flared are English. Depends on the year for the correct hose.
Since this is a return line, you can just use your old fittings and use low pressure hose.
I guess I need to clarify my problem/question. The return line on my steering is fine. However it is an o-ring fitting at the gearbox, and measures as metric. The pressure port however, appears to be SAE as a metric fitting will not go in it. So my question is, is this the normal setup? SAE for pressure even though the return is metric? And is there a way to be sure you get an SAE/flare. I ordered for a 1980 and ended up with a Metric/O-ring pressure hose. Help?!:confused:
