Oil leak from exhaust manifold bolt
Duck
- Oregon
- 76 CJ5
258 6, Weber carb, 3spd w/Dana 30 front with Jeep disc brakes and cut down Scout II Dana 44 rear with 11" drums, front and rear geared 3.73,Dana 20 transfer, reverse shackle lift on 31x10.50.
I have a AMC 258 i6 / 4.2l I6, just installed 2 months ago (long block assembly) by me. The intake/exhaust manifold bolt closest to the firewall seems to be weeping a little bit of oil down the side of the motor? Is this common? Can it be fixed? Easily?
The other thing to do would be to check the torque on that bolt. The head would have to be busted for oil to come out of there (usually it would be water before oil). Which should also mean that that bolt would not tighten up properly. Rod
