On Board Air Pressure Tank
duffer
- Media
- 9
- Bozeman, MT
- 1955 CJ3B: Dart/AFR aluminum 441 sbc, AGE M22W trans, "super" D18 w/ TeraLows & Warn OD, FF44 ARB/Dutchman Rear, D44 front-ARB/Reid/Dutchman, 4 wheel discs, York OBA, PP welder, 8274 w/ 9.5 XP motor/Zeon 12 contactor, glass/aluminum body, 33-12.5's;
1968 CJ5: all stock (V6/T86/D18/D27/D44) except 4bbl & headers and rear aux tank, HD rear 44 housing, Warn OD, Belleview winch, Whitco top (New Blue)
1968 CJ5: mostly stock (V6/T90/D18/D27/D44), unknown make 3" lift springs, 11" Bendix brakes, Warn OD, unknown electric winch, Kayline tire/jerry can carrier, Bestop Super Top (Old Blue)
1947 2A and 49 3A that may or may not get built, and several FC/wagon derelicts
I've been using an aluminum O2 tank for my York OBA for 7 or 8 years. Seems to me it was rated at something like 3000 psi. In my flatty, it was a bit too long to plumb the inlet fitting it between the frame rails so I machined the neck down about 1/2". That still left a good inch of material there. I also drilled and tapped it for a 1/4 NPT drain. Again, way more than ample wall thickness for an air system. My tank is also installed against the bed in front of the rear axle. At first I used one of Grainger's cable release drains on it but that was still a bit awkward. Then the Surplus Center had a bunch of GM diesel fuel shut off solenoid valves for cheap-they work perfect. I did add a stainless steel sintered filter on the outlet to keep any grit out of that valve.
As a bonus, you get to scare the Bgezzus out of unsuspecting people walking around your rig.
