oops.....I broke it and don't know what it is.
firedocs
Athens, Ga
1985 Jeep Cj-7 Black and Honey Laredo, hard top 5 speed manual, Bone stock head to toe-Factory A/C, stainless package, 258-I6, stock carter bbd, less than 100k miles.
Hey guys I was removing my Carter bbd tonight and inadvertently broke off this little sensor thing on the intake. I don't even know what it does, or better yet if I need to replace and where to get it..anybody?? This is my Carter/Weber swap and not off to a good start.
Tim
That part will be irrelovent with the Weber. It's a sensor (one of many) that helps the function of the computer controlled bbd and it's chaotic operating features. Disregard.
Its a air vane sensor for emission control..
Most everyone takes the hoses off and
eliminates it.
noflakid:punk:
Hey thanks guys for the speedy answers. Glad to hear I don't need it anyway, I am already dreading all those vac hoses and which ones stay and go...ughhh. But i am sure that the Weber will make me happy once she's on and working. thanks again everyone.
You need 3 basic vac lines, advance for the dizzy, pcv valve, and brake booster if you have power brakes. You'll need another if you plan on leaving the egr, and one more for the vac canister if you keep it. I don't have egr, power brakes, or the vac can hooked up.
Sent from my DROID2
Sent from my DROID2
OK I think I follow most of that, the Dizzy I got, the PCV on the valve cover I got..BUT the EGR? Brake booster? I do have power brakes and plans to keep everything else in place(Canister). All I have removed so far is all hooked up to the Carb and old factory A/C. The "mass" at the back of valve cover and some larger ones that come from the exhaust...not sure.
Ok, Waxer that looks like it might be a Weber or aftermarket Carb is it? I too have the two plates that sit under the carb and one has a brass port like yours, where does that hose go to? Mine has a plug on the end of it. And the EGR and brake booster shouldn't be moved anyway with the carb install correct?
Tim
I noticed that you do not have a fuel pressure regulator, or at least not in the picture. How is you weber doing for ya? Happy with the idle, acceleration and such? I am going to install on Sunday I hope so maybe by Monday I can give more insight and call it "done".
Thanks for your help
Tim
ok im jealous you two have some good looking cjs :notworthy: :chug:
I broke that same thing off over a year and a half ago, since I am rebuilding now I guess I will change.
