Members CJs Paparooster's 1974 cj5
paparooster
Graham Wa.
Rig: '74 CJ5
Motor: AMC 360 V8 Holley 670 Truck Avenger carb
Trans: NP435
Transfer: Dana 300 Twin Stick
Front axle: Dana 44 w/ Detroit Locker, Chromolly Axles, 4.88
Rear axle: High Pinion Dana 44, 4.88, Detroit Locker, Disc Brakes
Suspension: Blazer Springs.Others:Warn Winch, Via-Air onboard air, Red Dot rear heater, H.E.I Distributor, Dual Electric Fans, Custom front & rear drive lines, Toyo Tires 15 x 35 x 13.5, Painless 70 amp fuse buss, 140 amp alternator
1978 cj7 304 turbo 400 Quadra-trac transfer
]Hello toall JEEPER's , Here are some pictures and mods on my 1974 CJ5
Motor: AMCRig: '74 CJ5
Motor: AMC 360 V8
Transmission : NP435
Rear axle: High Pinion Dana 44 , 4.88, Detroit Locker, Disc Brakes
Suspension: Blazer Springs 360 V8 .
Others: Warn Winch, Via-Air onboard air, Red Dot rear heater, H.E.I Distributor, Dual Electric Fans, Custom front & rear drive lines, Toyo Tires 15 x 35 x 13.5, Painless 70 amp fuse buss, 140 amp alternator , video camera mount in cab... Elbe hills Gotcha trail 10-03-09 - YouTube
