PCV valve on a 304 motor
grunt
Connecticut
1979 CJ 304, 400 automatic
I have a Edelbrock carb and performer intake manifold. Where do I put a PCV valve at? I know the valve covers have no area for a "push in" type like a chevy 350. Thanks.
Unless I'm missing something the pcv valve goes in the valve cover and the hose will go to the vac. fitting on the bottom of the carb.
Hey derf up and to the left there is a tower thing coming out of the manifold. In the pic there are some washers sitting next to it.
What the heck is that I was looking at my Holly street dominator that i plan to use with my Tuned Port Injection swap and I could figure out what that is for??????
Like CJ said, that is a mounting boss for the throttle cable bracket. You can see the bracket bolted to the top of it. If you like I can take off the throttle bracket and bolt it on to the Holley Street Dominator manifold I have ready to go into my J10. That way you can see how it mounts.
thanks i am tracking now... kinda feel like an arr tard... but tracking. cant wait for my wiring harness so i can start the tpi
If you look closely in the second picture, you can see under the bracket that the vacuum port is covered. You'll either need to plug that port or find a 90 degree fitting to put there to be able to use it. Considering that there are two more ports on the other side, a plug may work well there.
Though you may have a different bracket that clears that port just fine.
Edelbrock makes 2 versions of the Performer Intake Manifold
You can get ERG or Non_ERG (with and without a PVC)
